Door is jammed ?????
Old Oct 21, 2005 | 10:24 AM
gamecockfan04's Avatar
Question Door is jammed ?????
Ok my car was sitting on ramps for about 2 straight months (front) due to engine issues and I finally decided to roll it off the stands. Now my drivers side door is jammed and will only open like 3 inches before it hits my front fender. I have to lift up on the door hard to get it open, so what am I supposed to do to fix this???
Old Oct 21, 2005 | 01:35 PM
TraceZ's Avatar
Re: Door is jammed ?????
If the car was supported by its wheels on the ramps there should not of been a problem caused by that.
Did you leave the door open for a prolonged time period that it could of sagged the hinge?
It sounds to me like a problem with the hinge. I'd recommend checking the hinges for play. You might end up pulling the fender and replacing the hinges. Get it all lined back up and replace the fender... or it might just need adjustment. Post a picture of the door to fender gap with the door closed.
Old Oct 21, 2005 | 01:38 PM
OK, with the door closed it has the same gap to the fender as the pass. side, but when I open it it kinda drops.
Old Oct 21, 2005 | 02:22 PM
TraceZ's Avatar
I'm assuming it drops at the rear? It sounds like you need to adjust the hinge, or replace it if it is showing excessive signs of play.
Adjusting it requires removal of the fender, which is not really that hard.
1) remove fender
2) open door and have a friend hold it up
3) loosen the hinge bolts that go into the carbody
4) have your friend lift the door up a little bit
5) tighten the bolts back up and test it
6) repeat if necessary
7) reinstall the fender, be carefull to get it lined up right.
I've had nearly the entire body off my car, hood, nose, fenders, drivers door...
Getting it all to line up perfect is challenging, but not impossible. Just be carefull and dont be in a hurry.
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
