removing trans.
Old Oct 19, 2005 | 06:59 PM
Chevycobb's Avatar
removing trans.
I pulled the engine and tranny out the bottom, and I don't want to screw anything up removing the tranny. Is it best to remove the tranny from the bellhousing or the bellhousing off the block? lt seems like the best way to do it is remove the trany from the bellhousing, but how do you get to that clutch fork bolt? not much room because it will only slide back an inch or so. or is there an easier way??
Old Oct 20, 2005 | 09:53 AM
OBE1 95Z28's Avatar
Re: removing trans.
Remove the tranny from the bell housing. As far as the clutch fork, unbolt the clutch slave cylinder from the bellhousing. Then grab the end of the clutch fork and pull it out and back, this will disengage the fork from the throwout bearing. The fork won't come completely out, but it pulls back a couple of inches to disengage. Now you can remove the tranny.
Old Oct 20, 2005 | 09:14 PM
Chevycobb's Avatar
Re: removing trans.
great, thanks! now maybe I won't have a day where I work 14 hours and have time to do it....like that will happen...gotta get his car done.
Thanks again!!
marlar98
Sep 19, 2015 07:53 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
reww86
Aug 29, 2015 06:04 PM
4586
Jul 31, 2015 06:03 PM
dolfan324
Jul 17, 2015 10:34 PM
