Starting a WS6 that been sitting for 2+ years!
Old Oct 19, 2005 | 08:38 AM
Pampered-Z's Avatar
Like the topic states. The car is a 97 WS6 that was parked 2+ years ago and left sitting under the cover. The car was not prep'd for storage, just pulled in the garage, turned off and the cover thrown over it and has remained in the same state!
I will change Batt and Oil.
I figure I can pull the ign. and crank the engine over to prime the oil system. Is there something I can spray into the intake to lube the valves and cylinders or do I need to pull the plugs and fog them?
I don't know why, I just have this gut feeling a ring is going to be rusted to a cylinder wall
Any suggestions would be greatly appreciated.
JB
Old Oct 19, 2005 | 09:03 AM
Honda Hunter's Avatar
Re: Starting a WS6 that been sitting for 2+ years!
Really good question. I would like to know as well.
Old Oct 19, 2005 | 11:28 AM
aggiez28's Avatar
click here and it will tell ya
brook
Old Oct 19, 2005 | 11:30 AM
Admiral94's Avatar
I would suggest you pull all the plugs, squirt some oil in there and turn it by hand if possible to make sure that nothing is stuck. After that you can crank it to prime the oil and then fire it up. Also it might not run that good with the gas that is in the tank now, probably stale. Top of the tank with fresh gas or ideally you'd want to drain it, but I know that is not feasible.
Old Oct 19, 2005 | 11:41 AM
Blue89Bird's Avatar
I'd suggest disconnecting the fuel line and routing it to a bucket, and then jumpering the fuel pump so it pumps out all the crappy stale gas.
Old Oct 19, 2005 | 11:46 AM
kmanRS/SS's Avatar
id definately try turning it over by hand before cranking it via the starter.
Old Oct 19, 2005 | 02:37 PM
madwolf's Avatar
Good suggestions in this thread. On top of that, your injectors may have rusted inside, preventing them from pumping fuel, so if it doesn't start, that is the first thing I'd check.
Old Oct 19, 2005 | 05:15 PM
uhhhhh John.... did you buy BigShow's 999 mile 97 WS6?
Or are you just helping him get it started?
Old Oct 19, 2005 | 05:50 PM
Grims's Avatar
Why would you let a WS6 sit for two years, WHAT KIND OF PERSON ARE YOU!
Old Oct 19, 2005 | 06:42 PM
Bert02SS
Guest
Posts: n/a
Maybe he just got out of jail?
Old Oct 20, 2005 | 11:09 AM
97TransAm's Avatar
John is thinking about helping BigShow get the car started... again. He's getting an idea on what should / needs to be done before "firin' it up". Trying to avoid any catastrophic blow up or damage to the "precious" car. The garage that the car has been in is not climate controlled and I wouldn't be surprised if there are critters living inside....
Old Oct 23, 2005 | 03:46 PM
Pampered-Z's Avatar
Man I wish it was mine!!! He is moving so the car has to get running so we can load it on the transport. I really hope hislack of attention on this pristine car hasn't ruined it! (I think the milage is only 942.)
Old Oct 23, 2005 | 04:11 PM
97formulakid's Avatar
942 MILES!!!!!! Holy obscenely low mileage Batman!!!!!!
Old Oct 25, 2005 | 12:58 PM
NeverEverSatisfied's Avatar
I say grab a Bible. Start to pray. And just crank and crank away. (Yes I am a poet and no I really did know it.)
Old Oct 25, 2005 | 01:09 PM
Bert02SS
Guest
Posts: n/a
"But your feet show it. They are Longfellows."
