ORY for '02 with stock manifolds
Old Oct 18, 2005 | 07:36 PM
Derek_91's Avatar
Just out of curiosity does anyone know of a company that would sell an ORY for stock manifolds to fit an 02 camaro? Ive seen them for 98-99 i beleive but not for an 02. What is the difference between those years? Thanks for the help.
Derek
Old Oct 18, 2005 | 07:55 PM
SSpdDmon's Avatar
Re: ORY for '02 with stock manifolds
You can get pipes from tbyrnemotorsports.com that bolt in place of the cats...or there's a Stainless Works oryp. I had the ones from tbyrne on my '99 and they seemed to work well. The SW y-pipe is on my '02 and I have an exhaust leak that needs a little welding. Just a matter of what you like I guess.
Old Oct 18, 2005 | 08:36 PM
94zLT1's Avatar
SLP sells the direct bolt up SS 3" y pipe that connects right to your manifolds for a 2002..go to ls1speed.com to order yours i thought about it but i have the loudmouth and hear it sounds bad w no cats
Old Oct 18, 2005 | 09:18 PM
mrr23's Avatar
bassani makes one also.
Bob's 01SLPSS's Avatar
Have a StainlessWorks Off Road Ypipe on my 01' SS and it has worked well for the last 3 years but It was pretty pricey if I remember, SLP also makes one too!!!
Old Oct 19, 2005 | 06:54 AM
teke184's Avatar
pricey, loud and drops ground clearance...for minimal gains.
had one on my 99....couldn't notice any difference other than sound
Old Oct 19, 2005 | 08:14 AM
SSpdDmon's Avatar
Unless they came out with something new, the SLP y-pipe is a replacement for your stock y-pipe and it will NOT eliminate your cats. Therefore, it's not an off-road y-pipe. You could probably pick up a used one for less than $100 if you want to get rid of the flat spot in your stock y-pipe. But, to get rid of the cats, you'll need a SW oryp, MAC oryp, Bassani oryp, or those Mufflex cat-delete pipes I told you about earlier. The funny thing is, for a little bit more money (less than $600), you could get longtubes and an off-road y-pipe. So, why even bother tinkering with it unless you're getting it for free?
Old Oct 19, 2005 | 02:32 PM
Derek_91's Avatar
Thanks for the replys. I was just curious about one because i kinda am just looking for sound and if i have to it will be easier to unbolt and put the cats back for inspection purposes. I already got nailed once, which is a long story, so dont really want to again. But really, how much of a difference in sound will i notice. I have a magnaflow cat-back. Thanks again.
Derek
Old Oct 19, 2005 | 06:36 PM
teke184's Avatar
i had the magnaflow....and put an orp on....
it's a big difference. alot more rasp
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
spearous
Jan 12, 2015 11:03 AM
Jan 5, 2015 07:14 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
