bilsteen strut with drag springs
Old Oct 18, 2005 | 06:16 PM
romoranger's Avatar
basically i am taking off my lowering springs, they really are bad for the 60 foot and now that the car is solely a race car i don't know why i have them on. i already have bilsteen HD struts on them. i want to do the eibach drag springs in the rear, and the hal springs in the front. would those bilsteen struts be bad for launching? would hal qa1's be that much more superior, or would the bilsteens give me some alright performance in a drag only car.
Old Oct 19, 2005 | 07:58 AM
Greed4Speed's Avatar
Re: bilsteen strut with drag springs
They're not going to have to optimum valving for drags.
Old Oct 19, 2005 | 12:29 PM
You can't use a QA1/HAL drag spring an anything other than a QA1/HAL shock (or one with a similar diameter to the QA1 lower spring seat). The HAL springs are a smaller diameter on the bottom than the stock springs (or aftermarket Eibach, etc).
I doubt you would get good results with the Bilstein shocks (they are not struts - minor point). You want the front end to pop up on launch and help transfer weight to the rear wheels. That's why you use a shock like thge QA1 that can be set to minimum rebound resistance. There is no "damping" when the front end tries to come up. The Bilstein will probably offer substantial resistance to the front end rising.
The other advantage of the HAL's is the ability to adjust the front end height.
Old Oct 19, 2005 | 06:20 PM
romoranger's Avatar
injuneer, thank you very much. qa1's it is.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blkWidow
Sep 6, 2015 05:17 PM
Victory Racing
Apr 19, 2010 06:08 PM
Waste
Jul 31, 2002 11:59 PM
