Replaced some EVAP stuff. Still getting code P441.
Old Oct 26, 2002 | 05:18 PM
BLK96Z28's Avatar
Angry Replaced some EVAP stuff. Still getting code P441.
I replaced the EVAP canister, the canister pressure control valve and the purge solenoid valve bolted to the intake manifold. All AC Delco from the dealer. SES came back on with same code, P441, "...incorrect purge flow." What do I have to look for?
Old Oct 26, 2002 | 11:51 PM
The code page on the AutoTap site shows P0441 as "EVAP System No Flow During Purge". That would indicate that the solenoid is not opening, or the line from the canister is plugged. I believe if there was an electrical feed problem to the solenoid, you would get P0443 as well, so it would seem to be a plugged line.
Old Jun 18, 2003 | 10:04 AM
jeremyferguson's Avatar
If your canister was cracked on the inside and sending charcoal up through the lines, they could be clogged by charcoal still.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
CobraEatr
Jul 29, 2002 11:46 AM
