LS1 Brakes - torque specs
Old Oct 15, 2005 | 12:03 PM
SnakeOiler's Avatar
I'm in the process of upgrading my brakes to the LS1 style. Although I can find lots of information on the upgrade itself, I cannot find torque specs. I used the LT1 ratings for the ball joints and tie rod - as I didn't see the there would be any difference in those. But, I could see the calipers more than likely being different.
Specifically, I am looking for torque rating on the following:
1) Caliper mounting bracket bolts
2) Caliper bolts.
If anyone can point me in the right direction or provide these numbers, I would most appreciate it.
Thanks.
Old Oct 15, 2005 | 12:13 PM
Klypto's Avatar
Re: LS1 Brakes - torque specs
if i read your question right... ive taken the brakes off my z28 many a times, and i just hand tight them back on... works fine, and its been months....
cory
Old Oct 16, 2005 | 07:50 PM
SnakeOiler's Avatar
I don't think I want to go hand tight - I'm sure they back themselves out, my fingers aren't that strong
I think the caliper bolts I'll set at 30 ft.lbs
I know the mounting bracket bolts on my truck are spec'd at 150 ft.lbs. - so, since the car is lighter and has smaller brakes, I'm thinking maybe somewhere in the range of 100 - 120 ft lbs.
Doesn't anyone have a service manual for there LS1?
Old Oct 16, 2005 | 10:14 PM
LWillmann's Avatar
I didn't get the abutment bracket bolts that hold the brackets to the spindle tight enough and one came all the way out, and the other loose, letting the caliper move around and chew up the inside of one of my new $300 wheels.
When I checked the Haynes manual for the torque specs when putting it all back together, the book called for 74 ft. lbs. I believe. I also used some RED loctite for a little extra insurance.
Old Oct 17, 2005 | 10:31 PM
SnakeOiler's Avatar
Hey, thanks.
That's sounds like a good number to me.
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
