How can I check the codes
Old Oct 14, 2005 | 11:32 PM
gasnmyveins's Avatar
without buying a code tool? ($30 paper clip) My durango will flash the codes if I turn the key on and off in a certain sequence. How about f-bodies? I might finally buy one tomorrow, and I'd like to be able to check so I don't end up buying someone elses problem. Thanks.
Old Oct 14, 2005 | 11:43 PM
Kris93/95Z28's Avatar
Re: How can I check the codes
What year is your car?
For the 4th gens: If its a 93, you can use the paper clip trick. 94+ you need a scan tool. On thing to do if you need to know a code, and don't want to buy a scanner. Autozone will scan your car for free around here, see if they'll do it where you're at too.
Old Oct 15, 2005 | 12:37 AM
That's right. I forgot all about autozone. I might be buying a 94 tomorrow. Hopefully there is an autozone near him. Thanks.
Old Oct 15, 2005 | 02:32 AM
lt11997's Avatar
Autozone will only scan OBD2 cars.
Old Oct 15, 2005 | 09:06 AM
Wonderful. What year did these cars go to obd2?
Old Oct 15, 2005 | 09:10 AM
1996
Old Oct 15, 2005 | 09:15 AM
anaik's Avatar
Here's a list of scanners for OBD 1 & 2.
http://members.aol.com/FWForsythePE/HowTo/Scanner.htm
Old Oct 15, 2005 | 11:11 AM
The "links" in that list and the model numbers are out of date. Its just too much work keeping up with the changes.
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
91Bird305
Aug 5, 2002 01:39 PM
