99 Z won't start
Old Oct 26, 2002 | 10:59 AM
TheWidowmaker's Avatar
Angry 99 Z won't start
I drove it to a friends house, came out and it wouldn't start. I know that the voltage isn't getting to the solenoid to kick over the starter. Any ideas why?
99 Z28 no mods yet
stroke it?
Old Oct 26, 2002 | 02:49 PM
AJD99SS's Avatar
If your interior lights flicker while you turn the key and it also makes a clicking noise then you might as well just go buy a new battery. Thats more than likely your problem.
Old Oct 26, 2002 | 03:46 PM
thanks for the help but the batteries good. any other ideas?
Old Oct 26, 2002 | 03:56 PM
nikkev's Avatar
The chip in the key maybe?If you have another set of keys try them.
Kevin
Old Oct 26, 2002 | 04:10 PM
thanks but tried both keys already. keep the ideas coming.
Old Oct 26, 2002 | 07:33 PM
2000TA's Avatar
Well it might be the starter Solenoid. Is there any sound when you turn the key or do you not get any noise at all? this can help me pinpoint the prob.
Old Oct 26, 2002 | 07:43 PM
94TeALFiReBiRd's Avatar
if im right if you blow a certain fuse the engine wont start..
Old Oct 26, 2002 | 08:54 PM
Unhappy
thanks but checked all fuses and no noise when I try to start it. The voltage isn't even getting to the solenoid. Already pulled the starter to make sure it worked. bTW it's easy.
Old Oct 26, 2002 | 10:13 PM
nikkev's Avatar
Question
Try arming and dis-arming the alarm a couple of times.My '95 would do this occasionally and I had to fiddle with the alarm to get the car to start.For some reason the car thought someone had tried to steal the car and had the starter shut off.
or
Are you getting noise from the fuel pump?That little buzzzzzz coming from the back when you turn the key forward?If you aren't then try to see if you are getting voltage the fuel pump.If you are getting voltage but no noise = bad pump.No voltage means the problem is somewhere else.
If that's not it then I'm out of ideas man,sorry.
Kevin
Old Oct 26, 2002 | 10:35 PM
2000TA's Avatar
Ok Electronics is my field but however it is harder to explain than do it myself. So here goes my best.
1. how do you know that there is no voltage getting to the starter solenoid. Did you test it with a volt meter?
2. if so using the volt meter check the battery voltage and trace it all the way to the starter solenoid. You should have the voltage all the way down there even with the key off… on the solenoid there should be another wire that has no voltage with the key off….. hook up on that wire and try to start the car and see if you get voltage ( don’t be under the car when this is don’t you will need ling test wires to have the volt meter where you can see it) if you do not get voltage than you will need to follow that wire back and see where it loses it power at. BTW Auto Zone and other part stores will check you starter out for free if you have not done that yet.
Try that and let me know
I will take a look at my car and see if I can find anything else it could be tomorrow
Old Oct 26, 2002 | 11:00 PM
Angry
thanks. I can hear the fuel pump spooling up when the keys turned on. Also, I checked for the voltage at the solenoid and it is MIA. I think the voltage comes straight from the PCM so I'm gonna try that tomorrow. Please keep the ideas coming.
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
