rear hatch demister
Old Sep 15, 2005 | 11:36 AM
gsewell_uk's Avatar
rear hatch demister
Now that the UK mornings are getting a little cooler and wetter, I have noticed that my rear window demister switches off in less that a minute.
I have a 1996 Camaro Z28, is this normal or what do I need to do to increase the time before it switches off?
Old Sep 15, 2005 | 11:51 AM
Bow94z's Avatar
Re: rear hatch demister
mine does the same, just push it on again
Old Sep 15, 2005 | 12:07 PM
n2ceptor's Avatar
Normal time is around 10 minutes, then if turned on again 5 minutes..... Might be the switch is bad....
Old Sep 15, 2005 | 01:54 PM
Wow, the start of the yearly question about the defogger shutting off too soon. It's like a ritual around here.
The age of the system seems to cause an increase in electrical resistance that causes the breaker to be over-taxed. I put in a 30 amp fuse in instead of the breaker years ago. It has worked fine ever since. Keep some spare fuses handy just in case you need them. They don't reset like a breaker. The power seats are on the same circuit.
Old Sep 15, 2005 | 02:18 PM
moparman's Avatar
I also used a fuse instead of the breaker, after putting two breakers in and both failed in about three weeks. The fuse hasn't failed yet, and it's been in there a couple of years.
Old Sep 17, 2005 | 11:04 AM
gsewell_uk's Avatar
Shoebox,
Many thanks - once again - you were spot on. Replacing the breaker with a fuse (of the same rating) has solved the problem.
Cheers,
Graham
shroyvin56
Apr 3, 2015 08:15 AM
Jan 13, 2015 09:52 PM
siguy
Nov 27, 2014 10:07 AM
Bando
Oct 7, 2002 07:36 PM
regular Joe
Aug 8, 2002 03:47 PM
