Help! Metal piece broke out of Taylor wire
Old Sep 10, 2005 | 11:35 AM
mark896's Avatar
Angry Help! Metal piece broke out of Taylor wire
Comparing it to another wire, I managed to stick it back in as far as it will go but it still doesn't quite look like the others.. This plug change was going perfect until #8 too!
Can I still use this wire? Need help as fast as possible guys, thanks.
Old Sep 10, 2005 | 11:55 AM
tc3's Avatar
tc3
Re: Help! Metal piece broke out of Taylor wire
if you are talking about the metal terminal that connects to either the spark plug or coil, i wouldnt use it or at least not for long., i killed one coil with that and then the second one started arcing bad until i changed the wire, but this was with the coil wire on my lt1 but will be same...
Old Sep 10, 2005 | 12:00 PM
mark896's Avatar
It's the metal piece in the connection between the actual plug and the wire, not the one between the wire and the coil. I should've distinguished that. I managed to jam it back in there and it SEEMS ok. Won't know until I put it back together and run it though.
Old Sep 10, 2005 | 12:23 PM
tc3's Avatar
tc3
just check resistance and if its not far off then dont worry about it, did you put some dielectric grease on it?
Old Sep 10, 2005 | 12:44 PM
mark896's Avatar
Ok, here's what I did. Everything's put back together, except I switched the #8 wire with the #2 wire. So if it's messing up I can see if plain as day. When putting the "bad" wire on plug #2, it clicked on with no problem. I'm about to start it up..
I used grease too.
Old Sep 10, 2005 | 12:52 PM
mark896's Avatar
Just fired it up and everything appears to be fine. I'm gonna wash it and then take it for a spin. I appreciate the replies man.
Old Sep 10, 2005 | 01:54 PM
tc3's Avatar
tc3
good to hear... its always such a relief when something gets broken but yet still works as good as new...
and at least now if you start to get a slightly rough idle when it heats up you will know exactly what it is...
Old Sep 10, 2005 | 02:22 PM
Greed4Speed's Avatar
Go to a performance shop and buy a new terminal, install and forget about it. Or reuse your old one. Just open up the ends, and crimp it back onto the wire.
Old Sep 10, 2005 | 09:53 PM
mark896's Avatar
That's exactly what I had to do. "Adjusted" the metal terminal a bit and shoved it as far as I could. Runs great.
CobraEatr
Jul 24, 2004 11:37 AM
Burn_Out
Aug 18, 2002 08:49 AM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
