1200 hp t56?
Old Aug 26, 2005 | 03:15 PM
DiabloGT's Avatar
1200 hp t56?
is there any t56 that can be built that can handle about 1200hp or more? im thinking of starting a build up at the end of this year with afr 227s and le3 cam and ptk turbo later, and i want a t56 or manual cause im bored of auto,can anyone give me a price estimate and sites where to get them from?
thanks
p.s. how much more work is it to convert from auto to manual, how much is the conversion kit?
Old Aug 27, 2005 | 07:37 AM
MEAN LT1's Avatar
Re: 1200 hp t56?
There are a couple of people making big power with a t56. Its just gooan cost a big penney. You may want to give G-Force a call or even D&D Peformance. They will get you were you want to be .
Old Aug 27, 2005 | 11:04 AM
DiabloGT's Avatar
Re: 1200 hp t56?
do you have an estimate of around how much it will cost?
thanks
Old Aug 27, 2005 | 06:41 PM
J-RODZ's Avatar
Re: 1200 hp t56?
G-Force has a race prep trans for about $5800. You can beat the hell out of it all day.You will break everything but that tranny.
Old Aug 27, 2005 | 08:16 PM
rskrause's Avatar
Moderator
Re: 1200 hp t56?
No T56 is going to stand up to 1,200hp fo r long if the car hooks up at all. However, since there may be just a handful of 1,200hp small blocks out there, do you really need a tranny that strong??? If you can afford a 1,200hp motor, you can afford the tranny, so don't worry about the price! The strongest T56 in general use is from G-Force. Price depends on exactly what you choose, but figure in the $6K range plus another $1,200 or so for the Street Twin. Another $3K for the rear end and a driveshaft and you will have a good $10K in your drivetrain.
The strongest manny tranny that could be adapted is a Lenco. But that would be far from plug and play. You would need a custom bellhousing and clutch setup along with the $6K tranny. It is truly good for 1,200hp though. Top gear is limited to 1:1 but you could do a 5-speed with 2.73's and effectively still have an OD ratio. I serioulsy considered this at one point. It's feasible, but very, very expensive. The tranny tunnel would need to be modded as well, and so on.
Have fun and start filling your piggy-bank!
Bxlt1
Sep 29, 2015 03:18 PM
Henson071
Sep 18, 2015 04:01 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
1slow93z28
Sep 1, 2015 06:22 PM
