help asap!
Old Aug 12, 2005 | 01:40 PM
whiTetAlt1's Avatar
help asap!
Hey im replacing my power window motor (driver side) and im trying to get the power side view mirror connection off and it seems stuck. Is there a release that I'm missing? I've seen shoebox's walkthrough of it, but I drive a ta so its sorta different.
Old Aug 12, 2005 | 04:19 PM
99blackSS's Avatar
Re: help asap!
I think I just took out the button panel. I don't know what the T/A is like, but if the power mirror joy stick is connected to the same panel that has the power window buttons... there are two clips on the sides of the control panel that hold it to the door piece. If it is by itself or not attached to the power window button cluster I'd still look for how it is connected to the door trim and unhook the whole piece.
Old Aug 12, 2005 | 05:31 PM
whiTetAlt1's Avatar
Re: help asap!
got it. i finished and put it all back together then I noticed I hadnt connected that tiny light bulb. lol, what is that connected to?
Old Aug 12, 2005 | 06:59 PM
99blackSS's Avatar
Re: help asap!
I don't know where it hooks up on the wiring harness if you mean at that end. I'd just look around, it has to be near by.
If you mean where does the bulb go, it goes in an area above the switches to illuminate them a little in the dark. Look for a small hole in the area above the switches, the bulb gets mounted above that hole on the back of that piece.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
