help asap!
Hey im replacing my power window motor (driver side) and im trying to get the power side view mirror connection off and it seems stuck. Is there a release that I'm missing? I've seen shoebox's walkthrough of it, but I drive a ta so its sorta different.
Re: help asap!
I think I just took out the button panel. I don't know what the T/A is like, but if the power mirror joy stick is connected to the same panel that has the power window buttons... there are two clips on the sides of the control panel that hold it to the door piece. If it is by itself or not attached to the power window button cluster I'd still look for how it is connected to the door trim and unhook the whole piece.
Re: help asap!
got it. i finished and put it all back together then I noticed I hadnt connected that tiny light bulb. lol, what is that connected to?
Re: help asap!
I don't know where it hooks up on the wiring harness if you mean at that end. I'd just look around, it has to be near by. ;)
If you mean where does the bulb go, it goes in an area above the switches to illuminate them a little in the dark. Look for a small hole in the area above the switches, the bulb gets mounted above that hole on the back of that piece. |
