Adding Coolant question...
Old Aug 8, 2005 | 08:30 AM
dtp's Avatar
dtp
Question Adding Coolant question...
Every car I had before my 98Z, I added coolant directly to the radiator.
Anyway recently my coolant light would go off which I know is unreliable, but I decided to change it yesterday. I also decided to check my coolant level which ended up being very low. So I figured I needed to add a little more coolant. (had my system flushed over 1.5 years ago.).
So I added some to the coolant reservoir. How long will it take the coolant to migrate from the reservoir to the radiator? My car is not overheating... Or do I have to add coolant directly to the radiator? (BTW I"m adding DexCool or whatever that expensive GM approved stuff is).
Old Aug 8, 2005 | 08:56 AM
flatlander757's Avatar
Re: Adding Coolant question...
you want the radiator to be full up to about 1in to 1/2in from the top. and then fill the reservoir up to the mark that it says on the dipstick kinda thing. don't forget to bleed the system!
Old Aug 8, 2005 | 08:58 AM
HBHRacing's Avatar
it doesn't migrate. If your radiator is low you need to add to the radiator. The over flow is just that, As the level in the rad rasies it will flow into the over flow, as it lowers in the radiator it will be pulled back in. But the raditator needs to be full first for this to happen.
Old Aug 8, 2005 | 09:50 AM
dtp's Avatar
dtp
I used to just add the coolant to the radiator and call it good, so how do I bleed the system? Thanks for the advice, the manual sort of confused me when I looked up adding coolant, I thought it said to add it to the reservoir if the car is not overheating.
Old Aug 8, 2005 | 11:03 AM
anasazi's Avatar
LT1 or LS1 car? LT1's are a pain in the **** to bleed but my LS1 was easy, pretty much just fill up the radiator after the thermostat opens then dump a bunch into the overflow and put the cap back on, it'll burp the air out.
if you do this on an LT1 however you'll blow a headgasket
Old Aug 8, 2005 | 11:20 AM
dtp's Avatar
dtp
It's a 98Z so that would be LS1, so I'm lucky here. What makes the thermostat open? Yes, I'm a newbie when it comes to looking under the hood. (biggest mod, changing battery cables, LOL).
Old Aug 8, 2005 | 11:55 AM
Originally Posted by dtp
...What makes the thermostat open? ...
Heat.
Old Aug 8, 2005 | 01:13 PM
dtp's Avatar
dtp
Originally Posted by shoebox
Heat.
Ok smart guy , so how do I get it heated up to where when I open the thing it doesn't spray me with hot steam, or do I just run the car with radiator cap off and just keep on giving it coolant.
Old Aug 8, 2005 | 01:21 PM
lt11997's Avatar
Just let the car run with the radiator cap off.
Old Aug 8, 2005 | 01:24 PM
... or do I just run the car with radiator cap off and just keep on giving it coolant.
Yeah, just idle it until it gets warm enough for the thermostat to open, keep the coolant in the radiator filled. If it start to overflow, put the radiator cap on.
Old Aug 8, 2005 | 01:45 PM
dtp's Avatar
dtp
Thanks everyone. Normally, I'd just go out and experiment, but I care more about this car than my previous car (Chevy Citation,LOL)...
Old Aug 8, 2005 | 05:24 PM
rngilliland's Avatar
From your first post I think adding coolant to the over flow was correct. You said your car isn't overheating but the level in the resevoir was low. Over time coolant will evaporate from the resevoir and need to be added.
Old Aug 8, 2005 | 08:06 PM
dtp's Avatar
dtp
Question Re: Adding Coolant question...
Get this... I started my engine with the coolant cap off and withing 30 seconds coolant started coming out of the radiator so I put the cap back on. WTF? I just put in a new sensor. Could my coolant be dirty and just need flushed. Oddly enough the reservoir was very low yesterday and I filled it. Today whenever I drove, I'd get a low coolant light... The car runs at around 180 to 190 degrees (stock thermostat).
Any ideas? Also the coolant light does not come on immediately, usually 2 minutes after I started driving.
Old Aug 9, 2005 | 09:48 AM
dtp's Avatar
dtp
Exclamation Re: Adding Coolant question...
Last question, can dirty coolant set off the sensor? The reason I ask is that when I start the car now, the sensor does not come on immediately, but up to 10 minutes after I start the car. I only added coolant to the reservoir and not to the radiator, because the radiator spit up coolant when I tried to add more making me think it's already full...
Old Aug 12, 2005 | 08:31 PM
dtp's Avatar
dtp
Guess what? The coolant can go from the reservoir to the radiator... My coolant light no longer comes on and the level in the reservoir dropped and is now constant. Go figure....
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
marlar98
Sep 19, 2015 07:53 AM
RX Speed Works
Sep 11, 2015 03:31 PM
