69 camaro heat problem, melting really
Old Oct 22, 2002 | 10:20 AM
kissel's Avatar
i have a problem with my domelight. The bulb (211-2) is getting real hot and melting the plastic domelight housing. i tried to find a different bulb and can't find one that fits. My next step is find a heat tape to keep the heat away from the plastic housing, still no luck.
i just bought some gasket stuff and think i am gonna try to place some form-a-gasket in the housing as a heat coating.
anyideas, i am sure that other people have had this problem
help!
kissel-
Old Oct 22, 2002 | 01:33 PM
Z28SORR's Avatar
This is sometimes caused by corrosion on the wires or bulb contacts causing a high amperage draw. Check to see if the fuse has a higher then normal rating, ie., 15 amp instead of 5 amp, usually a dead giveaway. Good Luck,
Old Oct 23, 2002 | 08:38 AM
kissel's Avatar
interesting enough i did change the contacts becauser they were rusted out . in order to change the whole harness i would have had to remove the headliner and i didn't want to do that. so i cut the new harness' clips and replaced those. it is still melting the unit. sounds like i am going to have to get more into this than i thoguht. not a quick fix by any means.
now i gotta figure out how the wiring harness attaches to the car and how to route it with out taking the headliner out.
kissel
Red Hawk 94
Mar 18, 2019 04:03 PM
Injuneer
Dec 15, 2014 09:36 AM
ro2207
Dec 4, 2014 06:18 PM
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
