last min tips?header install
Old Jul 31, 2005 | 10:51 AM
SilverStreak's Avatar
Ok so i got some longtubes to put on my car today(i have the day off) and i wanted to know if anyone had any last min. tips. Going into a 99 camaro, i'm pre-soaking the bolts in liquid wrench. and i have all the need tools besides a hack saw.
Old Jul 31, 2005 | 11:46 AM
Nick 02 Z06's Avatar
Re: last min tips?header install
1. Make sure you retrace the threads in the head itself. The best way is to take a dremil to the side of one of the bolts then screw it in to each one of the bolts hole to clean out the muck from the threads.
2. Get a buddy to help you out.
Old Jul 31, 2005 | 11:54 AM
Well i just drove the car so i gotta wait for it to cool down again. I went and bought some new header bolts just in case, and i bought some new sockets for the project as well as picked up two taller jack stands.
Old Jul 31, 2005 | 02:32 PM
Bayer-Z28's Avatar
I hope you know that this will take a while... It took me 14 hrs, and I've NEVER done this before...
You will need:
1- Patience
2- Time to kill, just in case...
3- I ended up breaking an EXH clamp. I noticed that my cat-back was loose...
4- 4x6 wood pieces, for cribbing... take a look at Teke184's cardomain page, he has a full write-up.. I used it...Basically universal advice...
It's worth the time.. I think I might go as far to say, I enjoyed it...
http://www.cardomain.com/ride/243722/11
Old Jul 31, 2005 | 02:59 PM
i'm having trouble getting the last bolt of the pass. side coil pack. Any advice?
Old Jul 31, 2005 | 03:14 PM
99blackSS's Avatar
I had to use a lot of different ratchet sizes and attachments, also agree with having a friend help at least to hold the headers in place while you put in the first few bolts. It was a while since my install but I think it would be easiest to reach the last coil if you unbolt the passenger side AIR tube first.
Old Jul 31, 2005 | 04:22 PM
egr's off, there is some kind of tube laying over the last bolt with no slack. the bolt is resessed a little to where a wrench won't work ethir...
Old Jul 31, 2005 | 05:50 PM
00Z28SS's Avatar
It might be to late, but I recommend locking header bolts. Mine have drawn out 3 times already. They seem to be holding this time though.
Old Jul 31, 2005 | 06:22 PM
still stuck on that bolt. I got the driver side up and the new header in place ready to be bolted in. I think i might try and get some of thoese bolts. where can you get them at?
Old Jul 31, 2005 | 07:40 PM
Use a small open end, a quarter turn at a time and don't ever put that bolt back in.
Old Aug 1, 2005 | 10:48 PM
gotta love the sound of open headers... ran into a problem though!
where can i buy o2 extentions for the front O2's and do i need to buy the back sims or only to pass emmisions?
Old Aug 2, 2005 | 01:33 AM
Casper Electronics is the company that makes the extensions and the sims. You should be able to get them from any one of the sponsers of this site. If you don't want the check engine light you will need the extensions. Make sure you continue to check those headers at the collectors and the flanges to make sure you don't have any leaks before you burn out a set of O2's. They can get expensive if you buy them from GM. Congrats, I bet it sounds bad ***.
Old Aug 2, 2005 | 08:46 PM
Awesome thanks man. I ordered a pair of extentions for texas speed. I'll wait for the sims till around emmision time lol. I guess i got one more question. Anyone make an egr block off plate for on top of the intake and will you pas emmisions if you take the egr off?
P.S. sry about all the damn questions lol
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jlo
Feb 23, 2015 12:20 PM
alex5366
Feb 17, 2015 09:07 AM
dmcdonald96
Jan 30, 2015 06:46 AM
