What cam???
Old Jul 23, 2005 | 02:53 AM
Z28 97''s Avatar
What cam???
What cam can i use for a Cali car? I need to pass smog so cant be to crazy. Looking for the best power cam i can get and still be able to pass smog here in cali.
Old Jul 23, 2005 | 08:44 AM
teke184's Avatar
Re: What cam???
with the right tune the TR224 cam will pass smog.
not sure if you can get away with ported stock heads too, but if you can you'd be making nearly 380s to the wheels since you have to run shorties or manifolds.
cam only probably about 360s.
Old Jul 23, 2005 | 09:04 AM
Greed4Speed's Avatar
Re: What cam???
The Stealth II (MTI) and CheaTR (TR) are both supposed to be able to pass.
Old Jul 23, 2005 | 09:09 AM
Z28 97''s Avatar
Re: What cam???
Im gonna run long tubes, cut out, and a ORY, i know they wont pass smog but ill bolt up the stock manifolds and y-pipe for that. Also getting a LS6 Manifold. I need the most HP possible Im trying to beat a 04 cobra...
The Stealth II is 224/220 .612 intake .612 exhaust 112 sep.
vs.
The CheaTR is 214/230 .601 intake .578 exhaust 117 sep.
vs.
The TR 224 is 224/224 .563 intake .563 exhaust 114 sep
I dont think the Stealth II wil pass smog though cause of the 112 sep. I might be wrong. Which one will make more power? With the the above setup?
Old Jul 23, 2005 | 04:50 PM
Re: What cam???
Stealth II 224/220 .581/.581 116*
The specs you gave are the S1. "S" doesn't stand for stealth here. There is more than just LSA that will help a cam pass the smog test.
Old Jul 24, 2005 | 09:48 PM
GPZ28's Avatar
Re: What cam???
Why would you think that ported heads would fail smog???
I have heard that the tr224 will pass. That is what I will be trying out. My plans are bout the same as yours.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
