Trans install-bolt on verter or trans first
Old Jul 3, 2005 | 09:24 PM
93transam1234's Avatar
i got the converter on the trans and i am about to jack it up in place. So when it is in place do i bolt the trans on first or the conveter?
Old Jul 3, 2005 | 09:37 PM
94zgreenmachine's Avatar
Re: Trans install-bolt on verter or trans first
I would bolt the tranny to the motor then bolt the converter. If you do it the other way something may not line up perfect and the converter could fall forward. I did this years ago on my monte ss. I thought I had everything right but the motor would not touch the tranny housing. I used the bolts to pull it together. Well.... It bent the flex plate and put such a load on the thrust side of the rear bearing that it ate the thrust side and plugged the oil pump. Fortunately there was no real damage. Replaced a load of stuff and became really **** when it came to putting the tranny back in. Somehow the converter fell forward. You'll know when you have it locked and in place.
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 23, 2015 12:59 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
