Advancing 02 LS6 cam
Old Jun 29, 2005 | 07:15 PM
Black9TA8's Avatar
Does anyone know if you can advance an 02 LS6 cam to bring down the power curve some? I don't need power after 6400, but would like more down lower. Has anyone done this? Would you have any piston to valve contact?
Old Jun 29, 2005 | 07:42 PM
teke184's Avatar
Re: Advancing 02 LS6 cam
6400 is only 200 more than stock....not too bad. and it's designed for good power across the band.
if you can run a .610" lift cam...i'm sure you wont run into any problems with the LS6 cam, which is less than .550"
Old Jun 29, 2005 | 11:46 PM
Black9TA8's Avatar
I've seen dynographs of the ls1 cam vs. ls6 and the ls6 doesn't start showing any gains until 4000 rpm. I was just wondering if by advancing the cam maybe 4 degrees or so, it would start pulling at more like 3500 without hurting the overall performance of the cam too much. I know it's designed for the top end pull. I think it's retarded 2 degrees from the factory. I guess not too many people use this cam, and for good reasons......I'm guessing it'll be hard to find someone who's run this cam advanced.
Noenav
Mar 1, 2019 07:38 AM
racecarz28
Mar 30, 2015 09:55 PM
armedtrigger
Feb 24, 2015 08:30 PM
hotrodyou1
Dec 20, 2014 10:05 PM
Noenav
Dec 6, 2014 07:35 PM
