Disabling Vats key pellet gone bad!
Old May 28, 2005 | 08:15 PM
SLeeper94Z's Avatar
Im curently trying to disable my vats , i looked on shoebox howto to disable teh vats , I use my multimeter to measure the ohms on the key pellet i get no reading!, can anyone help My car is a 94Z I just need to get the right Resistance So I can disable with a resistor
Old May 28, 2005 | 08:27 PM
tc3's Avatar
tc3
Re: Disabling Vats key pellet gone bad!
are you sure that the multimeter is on the right setting... and make sure your actually contacting the metal peice
when i did it, it brought up the right number instantly
Old May 28, 2005 | 08:31 PM
SLeeper94Z's Avatar
ok I think i got it to work the multimeters contacts were dirty, I got a 4.53 on the Ohm's.Does anyone know the resitor i would need?
Old May 28, 2005 | 09:33 PM
tc3's Avatar
tc3
i dont think that is a possible value???
http://shbox.com/1/4th_gen_tech2.html#pass_key
that is not in range of any of the values of the pelets?
check the cleanlyness of the terminals again, then the key, make sure everything is connected properly.
Old May 29, 2005 | 02:04 PM
SLeeper94Z's Avatar
I checked with the ohm meter again and got 4.54 area , that would be pellet 11 range , can someone give me a resistor or a combo of resitors that would equal that, I bought a 4.70 1/2 resistor and it did not work can anyone point me in the right direction thanks
Old May 29, 2005 | 05:17 PM
tc3's Avatar
tc3
if it is number 11 then this should work...
http://www.radioshack.com/product.as...Fid=271%2D1124
are you sure you did the wiring right... when you are done, one side of the wire will be dangling around with nothing attached, just want to make sure because it took me a few tries when i did it
Heathen1
Jan 2, 2016 04:27 PM
beltrunner
May 17, 2015 10:18 PM
Noer
Feb 28, 2015 11:29 AM
Lakebratt
Feb 5, 2015 07:55 PM
Hoodshaker
Aug 27, 2002 02:32 PM
