OBD1, Code 48 MAF Circuit Problem
Old May 26, 2005 | 12:21 PM
Formula_driva's Avatar
This is the code I currently have thrown, I tried cleaning the MAF real good, but it didnt fix the SES light...Whats the problem??
Old May 26, 2005 | 02:36 PM
Re: OBD1, Code 48 MAF Circuit Problem
You might have lost the power supply to the MAF. Key on, engine off pull the harness connector off the MAF sensor and check the pink wire for +12V. If you have power, check the rest of the connector for bent or corroded pins. If they are OK, swap in a known "good" MAF sensor.
Old May 26, 2005 | 04:02 PM
I put in my cousins MAF to see if the SES light went away...and it did...So I guess I need to check the MAF out or get a new one
Injuneer
Dec 15, 2014 09:36 AM
pete53
Dec 9, 2014 07:31 AM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
Darth Xed
12
Jun 27, 2002 07:46 PM
