Dumb question about belts?
Old May 25, 2005 | 10:25 PM
dtp's Avatar
dtp
What can make a belt squeek other than poor tension? My POS mechanic said my belt has proper tension even though my car squeeks until it warms up and the squeeks appear to be effected by RPMs. I had the same problem a year ago and got the belt changed and the problem went away until now. I my mechanic just a POS and it's loose or can it be something else? Thanks. (BTW the belt looks fine visually inspecting it)
Old May 25, 2005 | 11:10 PM
OBE1 95Z28's Avatar
Re: Dumb question about belts?
Poor tension would make the belt vibrate/flap around. I've had perfectly good looking belts squeal. I'm presently running a Goodyear Gatorback belt that's been on there for 50K miles with no issues.
Old May 25, 2005 | 11:14 PM
Knowklew's Avatar
belt brand seems to make a difference, along with belt design such as the gatorback belts
Old May 26, 2005 | 01:16 PM
dtp's Avatar
dtp
Thanks so excuse my ignorance again, how hard is it to replace the belt myself, keeping in mind I have not done this since I owned a chevy citation... Is it a total pain to get the tension right as in using a crowbar to tighten things? This squeeking bugs the heck out of me...
Old May 26, 2005 | 02:27 PM
OBE1 95Z28's Avatar
The LT1 has a spring loaded tensioner so no adjustment is needed. Jack up the front of the car, relieve the spring tension on the belt tensioner with a 13mm socket and a long ratchet or breaker bar and remove the old belt. Take note of the routing of the belt to replace the new one.
Old May 26, 2005 | 08:42 PM
dtp's Avatar
dtp
Thanks!
Magenta_Hearts
Mar 29, 2017 08:54 PM
grabbem88
Feb 23, 2015 09:41 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
donot_4get
Sep 14, 2002 08:03 AM
