MAF-translator be used to cure cam-surge?
Old May 18, 2005 | 10:11 PM
teke184's Avatar
well...can it?
i seem to have a reasonable amount. not to mention i think i can squeeze more out on the WOT end of things.
just wondering if adjusting the part throttle a/f would possibly cure cam surge.
thanks
Old May 19, 2005 | 02:32 AM
redcamaroz28's Avatar
Re: MAF-translator be used to cure cam-surge?
It will not help in cam surge. A MAF translator will cause your car to run leaner (Only affected at WOT since the computer will compensate up to a certain degree to make your run 14.7:1 in part throttle driving). Things that will help surge is more timing added or running richer than 14.7 (which can be done by maxing out your BLM's).
Ryan
Old May 19, 2005 | 01:46 PM
bunker's Avatar
Yup more timing and more fuel limit the STFT integrators to run richer where you like it, and disable rich codes in PCM works wonders.
Old May 19, 2005 | 05:02 PM
teke184's Avatar
so this is a full on dyno or mail-order tune thing..
damn...
PCLZ28
Dec 24, 2015 05:19 PM
Zuvell
May 15, 2015 08:18 PM
detska
Apr 25, 2003 06:40 PM
Espo
Mar 9, 2002 01:15 PM
KevinSS
18
Dec 6, 2001 04:46 PM
