Purge question...
Old May 13, 2005 | 12:59 PM
LWillmann's Avatar
Purge question...
I was just out and about.
I opened the bottle, turned on the system and hit the purge. I got no cloud.
I could see the nitrous for just a few inches above the outlet, then it disappeared.
It's almost 90 degrees outside, so I didn't know if that would have anything to do with it.
I could hear it, and when I sprayed the car I could feel it, but not as strong as the last time I sprayed it on a cooler day.
Old May 13, 2005 | 01:21 PM
arieso94Z28's Avatar
Re: Purge question...
When was the last time you filled your bottle? You might be running out, or you need to check your pressure also, cause even though its 90 degrees outside doesnt mean your bottle will get hot. Do you have a bottle heater?
Old May 13, 2005 | 01:49 PM
LWillmann's Avatar
Bottle pressure was about 900 when I opened it, and I was running the heater when I purged it and sprayed the car.
Old May 13, 2005 | 03:49 PM
Aries's Avatar
you're probably just running out of nitrous in the bottle. Remember that pressure doesn't mean that there is gas in there. It could all be hot air.
Old May 13, 2005 | 06:01 PM
LWillmann's Avatar
The bottle was low. After I got home, I couldn't get more than 650 psi of pressure.
It drained off pretty quickly too. Time to get it filled again
Old May 14, 2005 | 12:31 AM
funina91ss's Avatar
The story of my life
Old May 18, 2005 | 08:03 PM
LWillmann's Avatar
New question, but still purge related...
If I open the bottle, heat it to 900-950 psi. When I arm the system and purge, I get a cloud. If I wait about 5 minutes and hit the purge again, I get just air, then another cloud.
Is that normal?
Old May 18, 2005 | 09:35 PM
funina91ss's Avatar
Is that normal?
That is the reason for the purge it gets fresh liquid N20 to the Noid.
Old May 19, 2005 | 07:05 AM
whatsup's Avatar
How much nitrous do you loose when you purge?
Old May 19, 2005 | 07:38 AM
LWillmann's Avatar
I realize that is the reason that you purge, but my question is if it is normal to purge and get a cloud, then wait a few minutes and if I purge again I get just gas for a second then a cloud again?
If it's normal, then I'll put it out of my head. I worry that there might be a leak or something causing this though.
I doubt you lose much during a normal purge. Now if you stand on the button, sure you'll lose a lot, but it normally doesn't take much to get to the liquid in the lines.
Old May 19, 2005 | 10:14 AM
First, there shouldn't be any "air" in the system, unless you just swapped bottles.
What happens is that the nitrous in the lines near the solenoids heats up from the engine heat, and changes from liquid phase to vapor (gasseous) phase. When you open the purge, the vapor phase nitrous blows out. Since its already in vapor form, it isn't visible. When the vapor clears (the reason you are purging), liquid nitrous hits the purge solenoid, and when it enters the tube and then the atmosphere, it changes from a liquid to gas by absorbing heat from the air. It also absorbs heat from any water vapor in the air (aka "humidity") and creates a visible plume as the water vapor in the air condenses.
Short answer - yes, it is normal to not see the plume at first, if your solenoids or the main line are located where they are subject to heat soak from the engine.
Old May 19, 2005 | 10:32 AM
LWillmann's Avatar
Thank you very much Injuneer.
Old May 19, 2005 | 10:52 AM
Funny thing is, I've never used a visible purge location, until about a month ago....
http://cjcfo.fbody.com/members/injun.../DCP04344a.jpg
Old May 22, 2005 | 06:07 AM
BD380's Avatar
What do you think is the best spot for a "non-visible" purge?
Old May 22, 2005 | 10:56 PM
My solenoids were right behind the drivers headlight, so the purge dumped into the front fender, ahead of the plastic fender liner.
Quickss96
Jan 29, 2016 05:56 PM
350350
14
Aug 11, 2015 12:03 PM
Strick
May 26, 2015 11:41 AM
No4nRice
N2O Tech
Nov 10, 2002 09:10 PM
blackbird007
N2O Tech
Oct 19, 2002 12:51 AM
