cd changer help
Old Apr 23, 2005 | 04:52 PM
calee's Avatar
cd changer help
i just got a stock AC delco cd changer that goes in the back of my '00 camaro.It did not come with the bolts to hold it in place.what size and how long are they.Thanks for the help.
Old Apr 23, 2005 | 05:54 PM
ZeeVert's Avatar
Re: cd changer help
I have a similar problem. I bought a used CD changer and need to mount it.
As I understand it, there is a bracket that is welded to the trunk "shelf". There are two smaller brackets that are attached to the CD changer. One(?) nut holds the the changer down. See this exploded view...
My changer came with the two smaller brackets. I have ordered what I hope is the larger mounting bracket #23; part number 10276577. Haven't got it yet. When I do, I'll probably screw it down. Good Luck!
Old Apr 23, 2005 | 06:30 PM
calee's Avatar
Re: cd changer help
All i need is the nut.I will go to home depot and find it,i hope, thanks for your help, Cale
Old Apr 29, 2005 | 10:05 PM
ZeeVert's Avatar
Re: cd changer help
Oops. Got the bracket in. It's the right one, except you need TWO mounting brackets. The bracket is not painted.
P/N 10276577 BRACKET for $2.15 each plus shipping. 12 days from order date from GMpartsdirect.com.
See picture at....
Old Apr 30, 2005 | 12:37 AM
wu6fiend's Avatar
Re: cd changer help
I bought the bracket mentioned above, and mounted it with JB Cold Weld. Been a couple of years, and it is still rock solid. Looks exactly like the changer was installed at the factory. The changer itself attaches to the bracket with a single nut&bolt.
Desolate_Flux
Oct 23, 2002 09:34 PM
NunzZ28
Oct 5, 2002 10:53 PM
Blue89Bird
Oct 2, 2002 04:19 PM
xkatodude
Sep 9, 2002 02:28 PM
Paulberg
Jul 26, 2002 11:35 AM
