high rpm
Old Apr 18, 2005 | 07:49 PM
Even10Flow's Avatar
high rpm
today when i turned on my 94 camaro, my cars rpm in park and neutral has been at 2500 rpm instead of in the usual 1000 rpm area. does anyone know why this is? when i put the car into drive it goes on its own. when i brake it feels like the car is fighting against me to keep going.
Old Apr 18, 2005 | 10:29 PM
gauntlet009's Avatar
Re: high rpm
I had a truck that did pretty much the same thing. I dont know if it would be for the same reason but in my truck the throttle was sticking.
Old Apr 18, 2005 | 11:40 PM
ianwells100's Avatar
Re: high rpm
yeah, i'd give the throttle body, and ALL its sensors a clean... then reset the pcm and try from there
Old Apr 20, 2005 | 12:46 AM
Nitro's Avatar
Cool Re: high rpm
it's got to be one of the sensors on the trottle body I believe it's the TPS (Trottle Position Sensor)
Old Apr 21, 2005 | 06:32 PM
Camaro213.4's Avatar
Angry Re: high rpm
This is very weird but I have the exact same problem with my 1994 3.4l in park the RPM's are at 2500 I put it in drive and it goes back to 1000 on its own!
Old Apr 21, 2005 | 07:03 PM
Re: high rpm
i'd put money on it being the IAC - idle air control, sensor... kinda makes sense that that'd be the problem
Old Apr 21, 2005 | 08:43 PM
Talking Re: high rpm
I just posted like an hour ago about high rpm's and I just solved it!!!!!!!!!!!!!!!
I cleaned the plugs with an air compressor and messed with them while the car was running (in park of course) just turn on your car and plug and unplug the two sensors until the RPM's go down it worked on mine! hope it will work on yours!
Old Apr 21, 2005 | 09:58 PM
AM91Camaro_RS's Avatar
Re: high rpm
could be a vacuum leak somewhere, too. i'd check for that as one of the first things.
blac94Z
19
May 13, 2015 04:50 PM
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
PhantomTA
Aug 17, 2002 12:19 AM
