new mastercylinder needed with clutch change?
Old Apr 18, 2005 | 11:37 AM
teke184's Avatar
gonna be swapping in a Spec 4 w/ new flywheel and an upgraded slave cylinder soon.
is a new mastercylinder needed? the Mcloud is $300....
is it needed or just something nice to have so you can adjust the pedal?
Old Apr 18, 2005 | 03:44 PM
SSpdDmon's Avatar
Re: new mastercylinder needed with clutch change?
If you don't get an adjustable one, I was told you want to at least do the drill mod.
http://www.installuniversity.com/ins...r_cylinder.htm
Old Apr 19, 2005 | 01:52 AM
BirchMan98z's Avatar
I replace the slave every time I replace the clutch, don't think a master is needed, but for a heavy duty clutch like that it's possible.
Old Apr 19, 2005 | 05:26 PM
LT-14me's Avatar
Not sure if this helps but i have a spec 3 and i replaced the slave. Mastercylinder was fine.
Old Apr 19, 2005 | 05:58 PM
96SFLZ's Avatar
I have the spec III and left the stock master in there. If I had to do it again though, I'd buy an adjustable master...right now, it engages way too high (the pedal) for my liking. You can always take a chance and just leave the stock one in...and if you don't like it, then buy the McLeod.
Since you have a '99, I'd definitely replace the slave with an '01-'02.
Oh and if you do replace the master, make sure you've got someone else there to help you...that U-bolt is a PITFA.
Old Apr 19, 2005 | 06:13 PM
teke184's Avatar
slave, flywheel and clutch are already ordered...on top of it.
i guess i'll take my chances with the master...
thanks
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Don 97 SS
Jul 11, 2005 08:50 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
