Rag-Joint How-to?
Old Apr 9, 2005 | 02:59 PM
JaWdRoPn's Avatar
Rag-Joint How-to?
Need to change out my rag joint on my 97' T/A, does anyone have a how-to for it? or how about any tips etc etc. Any help would be greatly appreciated, Thanks!!!
Old Apr 10, 2005 | 03:03 PM
JaWdRoPn's Avatar
Re: Rag-Joint How-to?
Anyone???
Old Apr 10, 2005 | 03:06 PM
slayer6x6's Avatar
You need to replace the intermediate shaft with the u joint and everything. Its not hard, its just two 11mm bolts. The shaft from dealer is way overpriced, I would keep your eye out for people parting out camaros or firebirds and grab one from one of those. When you take the old shaft off, you have to make sure that the steering wheel does not move!
Old Apr 10, 2005 | 03:09 PM
JaWdRoPn's Avatar
Do you remove the shaft from where it connects to the power steering rack or from where it connects to the steering column by the firewall?
Old Apr 10, 2005 | 07:30 PM
slayer6x6's Avatar
You have to remove it from both sides so when your done there will be nothing between the steering column and the rack. Your gonna want to replace that whole shaft. Thats why you have to be careful not to let the steering wheel move.
Old Apr 11, 2005 | 11:04 PM
OBE1 95Z28's Avatar
You don't need to replace the shaft. The original rag joint is riveted in place. Drill out the rivets and the new rag joint comes with bolts and nuts to secure the new piece. You might consider replacing it with Unbalanced Engineering's rag joint eliminator. It's a solid disk instead of the stock rubber piece. If you want the rubber piece, Napa carries them.
Old Apr 13, 2005 | 11:19 AM
Eddie95Z28's Avatar
Another vote for the unbalanced engineering rag-joint eliminator. It is only $30 and greatly improved the feel of the steering over my old worn out rag joint.
http://www.unbalancedengineering.com/Camaro/
Old Apr 13, 2005 | 11:58 AM
Red96Lt1's Avatar
Yeah, no need to replace the shaft. Did mine without doing it. Just drill out the rivets like someone else said.
Old Apr 13, 2005 | 06:02 PM
slayer6x6's Avatar
I did not know that, if the joint in my new shaft fails I know where to look.
Feb 26, 2009 07:31 AM
RKHiPerformance
Aug 1, 2007 11:53 AM
silicuda
Aug 16, 2006 04:15 PM
MeanGreen97Z
Feb 13, 2006 02:36 AM
SplitFire
Jul 30, 2004 05:56 PM
