Removing door glass
Old Apr 7, 2005 | 12:07 AM
Alvin@pcmforless.com's Avatar
Removing door glass
I bought a new door for my firebird after it was damaged in a break in.
Whats the best way to remove the door glass? I want to reuse my old door glass because its already tinted with the rest of the car.
Old Apr 7, 2005 | 09:52 AM
TraceZ's Avatar
Re: Removing door glass
There are 3 rivets that hold the window into the main track. You'll need to remove the rivets and the window lifts right out. I have a thread detialing alot of the process here:
Link1
link2
Old Apr 7, 2005 | 01:12 PM
i wasn't clear.,. did you use bolts to bolt it back togehter?
What about the door hinges.. did you have to take off the fender to adjust the door?
Old Apr 7, 2005 | 01:52 PM
TraceZ's Avatar
Yes, I used bolts instead of rivets to put it back together. There are plastic washers you will need to replace that sandwich the glass and provide a mounting surface. Drilling out the rivets will destroy the original plastic washers unless you are super carefull (I had to buy new ones). I recommend using stainless fasteners with nylon ringed locknuts in leu of the rivets.
Yes, properly adjusting the door hinges requires removal of the fender. If you are carefull it can be done without removing the nose on a Camaro, bit I'm not sure about a Firebird.
Here are some pictures of the plastic washers / rivets / bolts:
PIC1
PIC2
Old Apr 7, 2005 | 04:31 PM
Awesome.. Hey I appreciate it..
One more question if you don't mind.. How did you take off your door handles? If your roll the window all the way up can you get to them?
I'm planning on restoring my 93 (hey its 12 years old now!) Part of it is a new door, new nose.. I haven't planned on taking off the fender but I guess I can do it if i need to.
Old Apr 7, 2005 | 06:14 PM
TraceZ's Avatar
The door handles are held on with 2 nuts inside the door. just put the window up all the way and remove the nuts. The actuator rod is held on the handle with a plastic clip. Rotate the clip around and the rod will disengage the handle.
The lock cylinder is held in with a "C" clip on the inside. Just slide the clip off to the side and the lock cylinder will come out of its hole. It has an actuator rod connected to it also.
Go to Shoebox's website for instructions on adjusting the window so it seals properly. There are a few different places to adjust it and move it any direction. He also has great instructions there for removing and reinstalling the power window motor. With his instructions and what I have given you in this thread you should be ready to completely rebuild the door.
Shoebox also has a video I shot showing the movement of the window regulator mechanism on a door that had the outer skin cut from it. It really gives a good example of how all the parts move together.
Old Apr 8, 2005 | 11:04 AM
Bow94z's Avatar
since your knida on the topic...how do you adjust a loose window, everytime i have mine halfway down, both windows rattle and make alot of noise?
Old Apr 8, 2005 | 12:11 PM
TraceZ's Avatar
It could be something is out of adjustment, Or it could be that the guides and tracks are worn out. The only way to know for sure would be to take it apart and inspect it.
DirtyDaveW
Dec 1, 2016 05:37 PM
blown94
May 3, 2015 12:48 AM
ShwaZedder
Apr 9, 2015 06:33 AM
sscott
Jan 17, 2015 04:30 PM
siguy
Nov 27, 2014 10:07 AM
