Y-pipe
Old Apr 2, 2005 | 09:37 PM
calee's Avatar
Y-pipe
is a SLP 2.5" Y-pipe a good mod to do on a '00 SS? is it worth the money? also a strut-tower brace? thanks for the info.
Old Apr 2, 2005 | 09:52 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Re: Y-pipe
a y-pipe is one of the many good, fairly low-cost... must be done... mods to get out of the way before attacking larger things...
a strut tower brace... is iffy imo... if your going all out to try and stiffen up the car... it would help and you can get them for like $80... subframe connectors will really be a vast, noticable improvement... but are not going to be nearly as inexpensive.
Jared
Old Apr 2, 2005 | 09:56 PM
calee's Avatar
Re: Y-pipe
Jared, thanks for the help. Cale
Old Apr 2, 2005 | 10:09 PM
99BlackTA's Avatar
Re: Y-pipe
If you want some good sound and to get rid of the restrictive stock convertors look for a set of off-road test pipes. They are some currently on ebay for sale too!
Old Apr 2, 2005 | 10:15 PM
frmula1's Avatar
Re: Y-pipe
why don'tcha link me brotha man =]
i've just been dropping the y pipe completely
Old Apr 2, 2005 | 10:17 PM
99BlackTA's Avatar
Re: Y-pipe
They appear to have just been listed last night too...
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Old Apr 2, 2005 | 10:25 PM
frmula1's Avatar
Re: Y-pipe
thank ya! =]
whats the word on those things kicken off an ses or messen with the o2's?
Old Apr 2, 2005 | 10:31 PM
99BlackTA's Avatar
Re: Y-pipe
I am not too sure. If it does throw a light then 02 simms are always the answer. The good thing about those pipes are that when it comes time for emissions you can unbolt them and throw the cats back on with ease.
Old Apr 2, 2005 | 10:41 PM
frmula1's Avatar
Re: Y-pipe
hmm dilemma... i'd like a higher note for just around town... but im in and out of my very tight, very large, pretty nice neighborhood at all hours of the night... so just starting up my car with the ws6 exhaust is enough to make me worry.... im gonna change y-pipes just to get rid of that stupid rusty flat thing. but for the track... i'll just keep taking the exhaust off... including the cats
Old Apr 2, 2005 | 10:50 PM
calee's Avatar
Re: Y-pipe
is the ls6 intake the same as the zo6 intake?
Old Apr 2, 2005 | 11:42 PM
frmula1's Avatar
Re: Y-pipe
yes... for the c5
the c5 has the ls6
don't mistake it for the zo6 c6 tho when it comes out...
thats got the ls7
i believe all 01 and 02 f-bod ls1's already came with the ls6 intake
i think you could probably get better gains elsewhere for the money tho since your low on mods... like me (just getting started with this car)
Jared
Old Apr 3, 2005 | 12:13 AM
calee's Avatar
Re: Y-pipe
what are the first mods that you are going to do?
Old Apr 3, 2005 | 01:36 AM
frmula1's Avatar
Re: Y-pipe
In this order: (including ones i already have installed/purchased)
Intake (free hood mods/box/filter)
manifold-back exhaust (including dual cutouts)
Free mods - hood, tb bypass, sensor sims, thermostat, manual fans
ET streets
pulley/possibly electric a/c
3200 stall converter & tranny cooler
shift kit
dyno tune
headers
throttle body
front brake upgrade
subframe connectors/bracing bars/torque arm.
suspension - looking for tightness and about 1.5 inch drop...
cam
injectors
ported heads
again, dyno tune
then some kind of forced induction down the road... also.. include a new rearend and built tranny in there as soon as the stockers fail
most of this may never happen... cause i don't plan on being able to keep the car in the army.
but thats about how i'd do it
im sure i left out little stuff
Old Apr 3, 2005 | 09:04 AM
Greed4Speed's Avatar
Re: Y-pipe
The converter will give you ~.5 sec quicker track times. Every A4 guy I've known when they look back after modding, have said that they would have done the converter before other mods like exhaust etc. It makes the A4 a whole different beast. Just get a trans cooler while you're at it.
Frmula, I would highly suggest moving the SFC's up on your priority list. The Earlier you get them on, the less rattles, squeaks, and misaligned parts you'll have down the road, especially since running ET streets. You can get waves in your rear 1/4 panels w/out them. Also make sure you have a budget set aside for a new rear end with those tires. You may never need it, but it is only a 7.5" rear.
The flat piece of the factory Y IS NOT RESTRICTIVE. It has the same crossectional area as a round pipe. That is oval tubing, like what they use in NASCAR only a smaller diameter. Do a search on LS1tech. If you are ever going to get headers or dual exhaust, don't waste your $ on a Y unless you plan on keeping the factory manifolds.
http://ls1tech.com/forums/showthread.php?t=139142
Scroll down to the Y-pipe section.
I suggest going over to LS1tech and reading all the newbie mod threads. They'll be at the top, orange, and stickied.
Old Apr 3, 2005 | 07:19 PM
teke184's Avatar
Re: Y-pipe
i agree with G4S
the ypipe is pretty useless and a waste of money.
i put a full 3" offroad ypipe on my 99 and noticed nothing other than increased sound.
the STB is a decent mod to keep the nose tightened up, and SFC are really good for making the car feel rock solid.
Quickss96
Jan 29, 2016 05:56 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Noer
Parts Wanted
May 4, 2015 04:58 PM
Ray66
Jul 22, 2002 11:55 AM
