Tunercat Help
Old Apr 2, 2005 | 04:50 PM
titter's Avatar
Tunercat Help
I dont have a cat on my car, so i want to disable EGR and the air pump from the computer, but in tuner cats i am having trouble finding where i can do this. i am guessing the Crank AIR Select would be the air pump, but what about egr? also should i enable or disable the C.A.R.S. system? the current bin file i found had it disabled. thanks in advance.
Old Apr 2, 2005 | 08:11 PM
turbo_Z's Avatar
Re: Tunercat Help
After you have removed the EGR and AIR, go locate the ecm switches and scroll down and uncheck the DTCs relating to them. Then find the EGR spark correction table and "0" out the fields. Lastly go to the ECM constants and again find EGR.. set the min/max enable rpm to its maximum value. CARS is the same thing as CAGS so if you have a 6spd and dont like being locked out of 2nd gear around town then leave it disabled.
Old Apr 2, 2005 | 08:44 PM
titter's Avatar
Re: Tunercat Help
thanks, i havent removed them from the car, but i dont have a cat, so the airpump is basically just wasting time heating up nothing.
MDZ28
11
Sep 24, 2015 09:15 AM
whitehooptie
Jul 22, 2015 10:25 PM
jdelaprida
Jun 27, 2015 08:30 PM
2QUIK6
11
Dec 11, 2002 09:38 PM
1BadBrd
Aug 6, 2002 07:04 AM
