door panel removal without electric windows
Old Mar 31, 2005 | 12:32 PM
ryantggrt's Avatar
i have a 97 camaro and im installing a few speakers, but how do i get the manual crank off?
also, the door lock indicator is being a PITA. any tips on getting that off?
Old Mar 31, 2005 | 12:48 PM
nothingeined's Avatar
Re: door panel removal without electric windows
On mine, I remove all the screws so the door will have some play. You just pull the crank back a little bit and push the door panel away until you see a c-clip holding it in place. Just wrestle that off and the crank will come off. Then just pull up, then away the door panel. My lock indicator just pulls off.
Old Mar 31, 2005 | 01:15 PM
ryantggrt's Avatar
does it pull off the metal wire for the lock? which direction should i be pulling in?
thanks so far
Old Apr 1, 2005 | 01:04 PM
Metal wire is not supposed to come off. It just unsnaps from the metal wire. It will be tuff if it is the first time, but over time it just gets loose.
cmyname1
Feb 19, 2015 08:38 PM
siguy
Nov 27, 2014 10:07 AM
yosshimura
Aug 14, 2002 07:29 PM
MilkyClr69
Jul 29, 2002 10:01 AM
Zomie
Jul 25, 2002 07:52 AM
