Make my alarm stop working.
Old Mar 31, 2005 | 06:08 PM
DWray's Avatar
I needed to change out my alternator, and as soon as I wiggled a wire, the alarm (Code Alarm) that hasn't worked in 2 years started doing it's job.
I cut the wires for the horn and ripped (yes, ripped) out the sensor that was zip-tied to the bottom of my steering column.
I can't start the car unless the alarm stops working, unfortunately neither of my remotes work.
How do I unhook the alarm while still being able to start the car? I don't want to just unplug it and take it out and not be able to start my car.
I don't care to have an alarm, I'd rather just have my car start.
Car is an '81 Z28, by the way.
Old Apr 3, 2005 | 12:47 PM
Blue89Bird's Avatar
Re: Make my alarm stop working.
Find the brain of the unit and the model number should be printed on it. Then Id call code alarm and ask them to either send/fax you a copy of the install manual so you can remove it all, or ask them how to disable it. There usually is a little button to push somewhere to disable it. Turn the key to on without starting the car, then hold down the button, then turn the key back to off and start the car.
Old Apr 4, 2005 | 09:07 AM
shouldaboughtthez's Avatar
you could always find the starter wires under the steering column and put those back together, there is probably a starter kill relay installed.
edman
Jan 25, 2015 02:41 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Rich_z28
Sep 13, 2002 03:35 PM
kandied91z
Aug 6, 2002 01:18 AM
