Big bang problem...
Old Mar 30, 2005 | 12:19 PM
TheBiz's Avatar
Big bang problem...
I am only titling this thread that wat because thats what I have.
Last night I went to the track. First pass started well, I got into second and tried to go into third. I missed the shift, so I clutched it and got it the second time. When I let out the clutch and pressed the gas, I heard a HUGE boom. It felt like someone had a chain rapped around my rear-end and just jerked on it when I came out if third. I immidiately pulled it into nuetral and coasted the rest of the way down the track.
I ran a second time thinking it was something I did, and it happend the exact same way again.
Rear-end, clutch, goblins? Help. I need a new clutch, the stocker is shot. I have a Spec III ready to go in. Would a bad stock clutch do that?
I am clueless. Any help would be appreciated.
Old Mar 30, 2005 | 03:11 PM
TraceZ's Avatar
Re: Big bang problem...
Transmission mount I bet.
Old Mar 30, 2005 | 03:14 PM
TheBiz's Avatar
That could be I guess. Any idea why it does it did it i third gear only? I just took the car out to check drivability today, and it shifted fine. I ran it to the shift light (6100) through 4 gears and it was smooth as a baby's butt. I still need a new clutch but, I'm cluless.
I will go check the tranny mount right now.
Thanks.
Old Mar 30, 2005 | 03:20 PM
TraceZ's Avatar
Thanks.
I didnt realize it was consistantly 3rd gear only. If it is absolutely limited to 3rd gear it would almost have to be the transmission.
The driveline loads up in all gears, and the problem only happening in third gear would seem to point to the transmission.
If it happenned in all gears, I'd be more suspect of different problems like the trans mount / rearend / clutch.
Old Mar 30, 2005 | 04:43 PM
TheBiz's Avatar
Well, new clutch goes in this weekend if all goes well. I will be able to tell something then.
Thanks for the help.
Old Mar 30, 2005 | 05:49 PM
CamaroSS30thAnn's Avatar
i get this really bad bang/rap through my whole driveline , center consol to the rear. this is when im at WOT or close to it when my a4 shifts
it will bang when the car shifts , and do it really bad when im spinning my tires
that would be my tranny mount??
btw my mount was ripped a little last year and i never got around to changing it and with the additionof new tires this year and driving my car a little harder than usual could have contibuted to the mount going bad , i did look under the car and it doesnt look to good lol
Old Mar 31, 2005 | 09:06 AM
Blue89Bird's Avatar
tranny mount
15 minute $15 job
*edit*
dont spin your tires anymore or go WOT, because well, that banging you hear, is your tranny smacking the floor of your car
Old Mar 31, 2005 | 09:39 AM
Originally Posted by Blue89Bird
tranny mount
15 minute $15 job
*edit*
yeah i realized that , so ive babied it the last two day slol
Old Mar 31, 2005 | 11:23 AM
BirchMan98z's Avatar
Broke many a tranny mount on my '95 and my '98... sounds like that's definitely your problem.
Old Mar 31, 2005 | 03:38 PM
yep that was my problem
i changed to a poly mount , i do not know y everybody bit(hes about teh vibration , mine barely has any and after driving it for a while u dont even notice it , i even took it up to about a hundred and nothing
when i took it off the rubber tore right away from the mount, who like torque?
Old Mar 31, 2005 | 04:17 PM
97FormulaWS-6's Avatar
The vib is a lot more noticable with a M6/Aftermarket shifter.. trust me... but even still it's not that bad, and once the poly loosens up you don't even notice it.
Old Mar 31, 2005 | 10:08 PM
haha yeah but a cammed motor , with polly motor mounts and tranny mount , haha forget it i hear its bad lol
Sep 18, 2015 03:46 PM
War Engine
Aug 21, 2015 05:28 AM
NewsBot
Aug 3, 2015 02:40 PM
Louey
Pacific
Jul 27, 2015 09:58 PM
dolfan324
Jul 17, 2015 10:34 PM
