Speedo Correction w/ TH400
Old Mar 23, 2005 | 09:32 AM
DelkT/A's Avatar
I have a 97SS w/ TH400 and LT1 Edit and I can't get the speedo corrected enough. Edit will only let me go up to a 4.96 gear ratio and I'm still 20mph off. Any help would be great!
Old Mar 23, 2005 | 10:40 AM
Re: Speedo Correction w/ TH400
One thought....
Did you start with an M6 program (17 tooth/rev) in the PCM? If you did, and assuming your TH400 has a 40-tooth VSS wheel, you need to switch the PCM to an A4 program, to get the 40 tooth/rev setting.
drt
Sep 27, 2015 04:39 PM
4586
Sep 27, 2015 01:55 PM
Fatdog2
Sep 16, 2015 11:04 PM
mmf_1013
Sep 12, 2015 08:56 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
