NX jetting for a 200 shot
Old Oct 12, 2002 | 03:53 PM
Derrick Redd's Avatar
Anybody know the fuel and nitrous jetting for a 200 shot with a NX shark nozzle? Thanks.
Old Oct 13, 2002 | 06:58 AM
Well I guess I'll call NX tomorrow and order the correct jets. Since no one is spraying a 200 shot.
Old Oct 14, 2002 | 05:26 PM
I called NX today and they gave me the jetting of 78N and 41F for the 200 shot. They also recommended that I upgrade to a bigger line going from the solenoid to the nozzle. 200 shot.
Old Oct 17, 2002 | 10:11 AM
Kraest's Avatar
Retired
Don't forget the flatbed
Mike
Old Oct 17, 2002 | 02:12 PM
JSK333's Avatar
Out of curiousity, how would you upgrade to a larger line when the fittings are already semi-permanent because of the built-in threads in the noid and nozzle?
Old Oct 17, 2002 | 02:19 PM
T/A lt1's Avatar
Uh oh Derrick I hope you pull some timing on a 200 shot or try it first and pull a plug to see if there is any detonation. I know there is a guy running an Impala with a 200 shot and he pulls quite a bit of timing but runs on 93 octane too. Good luck and I would like to see you run 10's too
Old Oct 17, 2002 | 05:08 PM
George Debski's Avatar
You must be talking about me
I run 1 deg on the 1st stage (80hp) then 3 more on the second stage (120hp) on 93 octane Shell. Total timing is 33 degrees.
Hey Derrick, I would seriously think about a new fuel system. That 255lph pump is gonna be on the ragged edge.
Old Oct 17, 2002 | 05:13 PM
396LT192's Avatar
I ran a 200 shot in my Vette one weekend and spent the next 4 months rebuilding it. I only had the stock pump though and it just did not have enough to keep up. I think I also had some bad gasoline. It would be wise to run 1/2 race gas 1/2 93 octane mix for a 200 shot IMO. I have heard the LT1 intake does not flow very well for nozzle injected nitrous over a 150 shot, but I think it is probably OK. My motor was a built motor as well, but detonation will kill the best motors. I was also retarding the timing 8 degrees. Just take the necessary precautions and make sure you can feed the fuel to the nozzle and to the motor.
FWIW, when I ordered 175 and 200 shot pills for my system, they said nothing about upgrading the lines from the solenoid to the nozzle, but it sounds like a good idea.
Old Oct 17, 2002 | 06:32 PM
Yeah, the three magic words:
FUEL, FUEL and more FUEL........
My fuel system can handle 1000+HP, and I'm only running around 550. Been running the 200 shot on the stock LT1 bottom for just about 3 years now. 1st stage 46/28, 2nd stage 57/33.
Old Oct 17, 2002 | 07:18 PM
RacinLT1's Avatar
Derrick,sorry,i didnt see this post sooner. Those are the same jet sizes i have for a 200 shot.
Also John Thomas (nmca/pro NX rep) said a -4 from the nozzle to the noid would be needed. He has some -4 lines with -3 ends so you dont need to go nuts swapping everything around.
Now i just gotta get my swaybar adjusted right and get this thing to hook,then i start with the 175 and 200 jets.
Old Oct 17, 2002 | 07:35 PM
I've ran the 175 shot a few times without any problems. I've decided not to go any higher than that. Why push my luck. When this stock bottom-end finally does go, a forged 383 or 396 with a 200 shot will be in the works.
Old Oct 17, 2002 | 08:51 PM
aziroc's Avatar
what size fuel pump do u need for a 200 shot? cause im going to be putting a 150 in for all the time and the 200 in for track/dyno days. i have a 255 now.. what all do i need to upgrade to make sure i got gernade this engine *but i have all forged interanal in this built 406* its just im running 10.4:1 comp.
Old Oct 17, 2002 | 10:26 PM
RSKrause is running 733 RWH with a single 255lph intank and a boost-a-pump to increase voltage. He's running a blown 383 with a 150 shot. No problems with fuel. So I have some faith in my 255lph intank pump.
Old Oct 18, 2002 | 09:39 AM
396LT192's Avatar
I was determined never to run out of fuel again, so I put a 255 pump in the tank as a replacement to the stock unit and in addition I added another 255 in the tank and a new 8an line that feeds into the drivers side fuel rail. The combo should support over 1000hp.
GREEN3112
Feb 10, 2019 09:19 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
