Speedo Recalibration with Hypertech after LS1 Edit?
Old Mar 10, 2005 | 08:29 PM
JS99Z's Avatar
After my cam change I had my car (99) tuned with LS1 edit. This year I want to do a gear change. Can I recalibrate the speedo with the hypertech without screwing up my tune? Thanks
Old Mar 10, 2005 | 10:00 PM
MakoLS1's Avatar
Re: Speedo Recalibration with Hypertech after LS1 Edit?
yea, it wont mess with your air/fuel or anything.
Old Mar 11, 2005 | 09:29 AM
SSpdDmon's Avatar
Sup J -
I think when you plug it in, it will ask you if you want to change the options before you "tune" the computer. After you say, "yes I want to make changes," you can tell it not to install the engine tuning and then change the rev limiter, shift firmness, gear ratios, tire height, etc. If you want, I'll walk you through it. Just let me know.
Old Mar 11, 2005 | 04:18 PM
Capn Pete's Avatar
Did you have the LS1 Edit tuning done at a shop, or did you do it yourself? Edit should be able to compensate for gear changes as well. If you're planning on buying a Hypertech, why not just bring your car back to the shop and have them plug in and change the speedo for you.....probably wouldn't charge much to make that simple change?
Old Mar 12, 2005 | 03:01 PM
JS99Z's Avatar
I wish I had LS1 Edit & a nice laptop. But I do have the hypertech. (thanks Jeff)
Old Mar 13, 2005 | 02:10 AM
L8ER's Avatar
Yeah it will ask you if you want the hypertech to tune it or if you want to pick from the list of options you want to change. So you can just change what you want to tire size, and speed rating, shift firmness and gear changes if any. Also temp for fans.
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
4586
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
