Trans cooler
Old Mar 10, 2005 | 08:07 PM
Jameslt1TA's Avatar
Trans cooler
Well i just ordered a B&M super cooler for my ol' 4l60e and it says that you should install it on the return line comming out of the radiator. Isn't it just like the 700r4 with the return line being the bottom one(i think thats what it said, not infront of me right now)????
thanks
james
Old Mar 10, 2005 | 08:29 PM
Projectz28's Avatar
Moderator
Re: Trans cooler
Yes the bottom line out of the rad is the return and that is where you want to install your cooler.
Old Mar 10, 2005 | 08:37 PM
Jameslt1TA's Avatar
Re: Trans cooler
Thanks!
this makes things easy since i dont have to take off the top line...only the bottom, cool.
Old Mar 11, 2005 | 05:20 PM
captaindbol's Avatar
Re: Trans cooler
HOLD UP!!
Have you cut anything yet? Remember, with the LT1's reverse cooling everthing goes backwards through the radiator as well as the engine. The return line comes from the TOP of the radiator. It is the line with the hose clamp on it if you are looking at things under the car. If you splice the bottom line you will be cooling the fluid BEFORE the radiator and negating any gains you would see from secondary cooling. Your not going to hurt anything by plumbing it backwards, it just won't be very efficient.
http://www.bfranker.badz28.com/94z/trannycooler.htm
james007moore
Jan 1, 2016 01:14 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
CARGASM
Sep 4, 2002 11:17 AM
