Tranny swap, throwing new code for TC??
Old Mar 7, 2005 | 12:44 AM
acid5868's Avatar
I just completed swapping out the 4l60e with another 4l60e in my 97. The moment I hooked the battery back up it threw a code. Scanned the car and it shows the code as: DTC P1860 TCC PWM Solenoid Circuit Electrical.
I am at a loss as to what exactly that means or how I go about checking to see what is causing it. More than anything I need to figure it out and get it fixed asap.
When I did the swap the only difference in the trannys was the electrical connector on the tail shaft. My old one was on the passenger side with a small plug, the New tranny had it on the drivers side and its a bigger connection. Since I had the other plug and the wires looked identical, I would assume its safe to splice the connector and plug it in. Not too sure what the sensor is.
Anyone have any input or advice. Help is greatl appreciated.
Old Aug 28, 2012 | 07:57 PM
Fred Willard's Avatar
Re: Tranny swap, throwing new code for TC??
If u get it fixed please tell me. I put a 94transmission in my 969696z28 same problem
Old Aug 28, 2012 | 08:08 PM
12SCNDZ's Avatar
You can't put a '94 in a '95-up vehicle. A '94 has one less solenoid for the PWM lock up. You'll never get rid of this code without swapping to the correct transmission.
Frank
Old Aug 28, 2012 | 08:10 PM
12SCNDZ's Avatar
Are you certain you didn't also install the wrong ('94) transmission?
Frank
Gtpguy
Jan 26, 2015 04:50 PM
Deadbolt24
Jan 19, 2015 01:29 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
91Bird305
Aug 5, 2002 01:39 PM
