Is my front hub bearing going out?
Old Feb 28, 2005 | 12:54 AM
AW/whiteZ-28's Avatar
I hear a squeak at low speeds sometimes from the left front could my hub bearing be going out, need grease, or is it anything else?
Thanks,
Archie
Old Feb 28, 2005 | 09:10 AM
Z28barnett's Avatar
Re: Is my front hub bearing going out?
The hubs cannot be greased or serviced in anyway, only replaced.
The front brake pads might be down to the wear indicator, it is designed to rub and make noise when the pads are worn thin.
Jack the car up and try to feel play in the hub, or have a shop do it. Hubs are 100-160.00 each depending on what you buy.
Z28
Old Feb 28, 2005 | 12:23 PM
Ok, I'll give that a try when it gets a lil warmer . Thanks
Old Mar 1, 2005 | 11:13 AM
NJSPEEDER24
Guest
Posts: n/a
Jack the car up under the lower control arm next to the wheel in question. Put your hands at 3 and 9 on the front of the wheel and push one side at a time. You can hear extensive play in the wheel bearings by doing this. While your at it, check your ball joints by putting your hands at 12 and 6 and doing the same thing. If you hear loud knocking the ball joints may be worn.
Old Mar 1, 2005 | 11:58 AM
Will do, Thanks
grabbem88
20
Dec 27, 2015 07:42 PM
Spcquinn
Apr 18, 2015 09:40 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
1LEThumper
Jul 14, 2003 12:45 PM
