Can i run a SC with this set up?
Old Feb 22, 2005 | 04:07 PM
NuMbNuTs670's Avatar
I got a walbro 255 HI PSI fuel pump, SLP 25p/h injectors, and NGK TR55 Plat. plugs. Will the plat plugs be ok to run 4.5PSI of boost without preigniting and detenating(sp), and are the injectors give me enough fuel?
Old Feb 22, 2005 | 10:10 PM
OBE1 95Z28's Avatar
Re: Can i run a SC with this set up?
I would stay away from platinum plugs; you risk pre-detonation.
Old Feb 22, 2005 | 10:18 PM
roguedriver's Avatar
If I were you, I would bag the platinums for sure, get a set of 30lb SVO injectors, consider running the 6psi set up instead of the 4, and get a tune for what you have so far, like maybe from pcmforless. And tune for that MAF also, although I would consider going back to the factory MAF.
Ken R.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
parkers Z28
Mar 11, 2016 08:14 PM
moneyshotz
Jul 27, 2002 06:16 AM
