just to confirm!
Old Feb 17, 2005 | 07:53 PM
EVERESTZ28's Avatar
just to confirm!
since is a 850 dlls invesment i want to be sure before order.
from what i had red here, this rim will fit on my 94 z28
15X10 with 7.5 bS, am i right?
and what is the bigger size of slicks i can go,? with out fitting problems, i want the slick inside my fender. is 28X10.5?
thanks for your help!
Old Feb 18, 2005 | 12:26 AM
Re: just to confirm!
This is a 15x10 7.5" backspace Weld Pro-Star, with a 28x10.5-15W ET Drag:
http://cjcfo.fbody.com/members/injun.../DCP03453a.jpg
http://cjcfo.fbody.com/members/injun.../DCP03650a.jpg
Also click on "Trailer Queen...." in the signature.
What you need to do with a 28" tire will depend on the specifc tire selection... not all 28" slicks are 28" diameter.... an ET Street can be as small as 27.3", the QTP's are generally 28.0", and the ET Drag can be closer to 28.5". The smaller tire will fit in the wheel opeing fine. The larger sizes may require relocating the axle backward slightly, and/or cutting the leading edge of the rubber bumper cover. And the width of the tire will deteremine how much hammering you need to do on the inner fender and possibly rolling the fender lip.
DirtyDaveW
Dec 1, 2016 05:37 PM
RX Speed Works
Oct 1, 2015 10:19 PM
NewsBot
Apr 9, 2015 07:10 AM
mobleman
Mar 15, 2003 08:44 AM
Draco
Pacific
9
Mar 11, 2003 12:28 PM
