OBD2 PCM edit options
Old Feb 10, 2005 | 04:55 PM
mitchntx's Avatar
For an LT1, OBD2 (96/97) F-Body, what options are there for a package to go in and delete parameters that would set codes?
For instance, if I were to buy a complete LT1 motor and computer from a '97 Z28 and use a Painless wiring harness and install it all in a simple street rod, I would need to be able to access parameters in the PCM so that the motor would run and run correctly.
If tweaking performance was of no concern, which program/package best suits this need?
Old Feb 10, 2005 | 11:11 PM
madwolf's Avatar
Re: OBD2 PCM edit options
You can either send your PCM in for reprogramming which is cheaper than buying the tuning program, or you can buy LT1_edit (which is the only option for 96-97 right now) for $550 and do the tuning yourself.
Most people choose to convert to OBD1 and then use Tunercat plus a regular converter cable (www.akmcables.com) to do the tuning themselves.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
rockync7
Jan 1, 2015 05:10 AM
Bando
Aug 2, 2002 02:18 PM
