Gear Pinion Spacer
Old Feb 8, 2005 | 06:26 PM
97Z2830thAnn's Avatar
Gear Pinion Spacer
Hello, i currently have 2.73 gears and was wondering if i get 3.73 gears for a 3 series carrier if the pinion spacer will be strong enough? As of right now i have a 2 series carrier and i would be buying 3 series carrier gears, would it be strong enough so nothing will break? Thanks
Old Feb 8, 2005 | 08:53 PM
ChevyTuffD.A.'s Avatar
Re: Gear Pinion Spacer
If your going to be buying brand new gears then just get them for a series 2 carrier, they are virtually the same in price.
Old Feb 8, 2005 | 08:55 PM
I'm not going to be buying new ones i found some good ones locally for cheap. Just wondering about the pinion spacer.
Old Feb 8, 2005 | 09:20 PM
I actually thought it was the ring gear that had to be spaced out. Anyway, I was told that spacers are not a good idea bc the longer bolts that need to be used have a tendency to work themselves loose.
Old Feb 8, 2005 | 09:23 PM
Hm, that would defenetely not be good, haha. Well, thanks a lot ill put some more thought into it.
Old Feb 9, 2005 | 01:20 AM
Pro Built Automatics's Avatar
Are you talking about the "ring" gear spacer?, or the thin pinion shim that goes under the pinion bearing to get the right pattern on the ring gear? If you are talking about a ring gear spacer, then they are not a real good idea if you have some torque & horsepower. Low HP & an automatic transmission does not seem to be affect it as much.
Old Feb 9, 2005 | 04:05 PM
I am talking about the product to make a 2 series carrier a work with a 3 series carrier gear. It is some kind of spacer. I just want to know if it is reliable enough for me to put it on and be a spirited driver with it. I only have basic bolt ons.
Old Feb 9, 2005 | 07:21 PM
You might be fine and then again u might not. I was told not to use the spacer so I went and bought 3.73's for a series 2 carrier. Its all up to u man.
Old Feb 9, 2005 | 07:59 PM
92RS305#2's Avatar
i'm not sure if its related but GM called my crush collar that i order from them a 'spacer', i'm not sure about what this pinion spacer your talking about. i know of pinion shims but not of any spacer other than what GM calls the crush collar.
Old Feb 9, 2005 | 08:06 PM
I beleive u are talking about the "crush sleeve" all it does is crushes down as u tighten the pinion gear nut and sets the endplay.
HarleyZ28
Oct 5, 2015 06:23 AM
TitoPR221
Jan 29, 2015 08:00 PM
derty
Aug 31, 2002 12:28 AM
kev93z28
Aug 19, 2002 12:48 AM
