vig 3200 any transmission mods????
Old Feb 8, 2005 | 05:44 PM
hambone3441's Avatar
With the vig 3200 do you just plug and play with this thing or do you have to make any pump/tranny mods??? Thanks.
Rob
Old Feb 8, 2005 | 07:37 PM
1SlowFormula's Avatar
Re: vig 3200 any transmission mods????
just put it in! the directions that come with it are a little convoluted. Unless you spent about a grand you didn't get the multi-disk converter that they tell you to remove the little check-ball valve in the instructions. Just be sure to get a tranny fluid cooler or you will cook the tranny, the higher the stall the hotter the fluid!
Old Feb 9, 2005 | 04:40 PM
mike 96 ws6's Avatar
i can't find a pricing list for the multi-disk Vigilante. got a link?
Old Feb 9, 2005 | 07:01 PM
I think they have it at thunder racing---
-----under supporting vendor index.
Old Feb 10, 2005 | 07:18 AM
No, I was wondering if I got the multi-disk because that was the only one with instructions in the manual then I called PI and asked what I had, but I called from work and didn't have the numbers on the side of the box. The girls said somthing along the lins of "If you didn't spend about a grand fro it you didn't get the multi-disk, and you should not remove that check valve with the normal converter it could wear it lockup clutch quicker then normal. The multi-disks were designed for more holding power and take a little more pressure to lockup, we recommend to remove that for faster lockup with the multi-disk"
This was all prompted by another thread like this one, when I was about to install mine. You can search for exactly what I found, it was fresh on my mind at that point, it has been a few months now!
Old Feb 10, 2005 | 07:21 AM
You are correct thunder has a 3 disk and a 5 disk on there site! both in the $900+ range
Old Feb 10, 2005 | 09:44 AM
Thunder Racing . that's what i was looking for, $989.99.
plus rebuild kit $ 454.34
plus tranny cooler $55.99
= i hope my banker is in a good mood.
Old Feb 10, 2005 | 11:30 AM
Unless you know what you were doing I wouldn't recommend trying to rebuild yourself search and you will find out why, but there are many reasons.
*** EDIT *** Hold on after reading what you just posted a little more, I think you are nuts and want to waste money so nevermind have fun with that combo!
Old Feb 10, 2005 | 12:17 PM
might not be a waste if
Like what I am doing............... a local tranny shop is offering their shop, tools, etc and the owner is going to personally assist me with the rebuild.
Old Feb 10, 2005 | 12:23 PM
True but even with that kit it is not optimal, yet is does have some good things in it there are also things that could be better, and in your case you have a professional watching over the work, but nothing says that it will come out well... There are way too many posts on here about local/reputable shops not knowing $hit about how to properly build a 4L60E. If you use the kit mentioned above, it does away with SOME of the downfalls of the 60e but not all of them! And a good local tranny guy usually just puts the sub-par gm replacements back in, that is why they fail again. Not to say your guy doesn't know what he is doing, but he may not know what the best thing for our cars might be!
Old Feb 10, 2005 | 01:13 PM
neil350's Avatar
I bought my Vigi 3200 from a board member for 415 shipped, these converters cost so much new and there are plenty of good ones on the boards. My only other mods to the trans is a B&M trans cooler.
Old Feb 10, 2005 | 02:18 PM
Yeah, that is why I like them they are good quality and you can send it back to be restalled, free in the first 2 years you own it then a couple hundred after that and it is like getting it refreshed! they realy are a good investment and there are not too many of those in project car mods!
Old Feb 13, 2005 | 02:01 PM
dyers98's Avatar
How do you like the 3500? I'm concidering getting one and want to know what people think. I wanted something alittle smaller (3000) but have a chance to get 3500 for a good price. Is there much difference there. Give me your thoughts.
Old Feb 14, 2005 | 09:01 AM
I am still getting used to it, I had a few problems when I went to the track where the OBDI computer hated it! I ran into the infamus stall wall, do a seach for more info if you are not sure what that means. But I finally got that computer fixed the weekend before x-mas, and I had to put it away, because of the bad weather. I will be breaking it out again soon and hopefully I will do pretty good this season!
As far as liking the 3500, well it was not my daily driver, but I have driven it to work and back a few times and in trafic it is a little different. It feels like you are racing the motor to move with other people, then you get them staring at you because it is soo loud, well I think that is my case anyway!
I like it and if you learn to live with a few things it is great!
rideordie
Nov 5, 2019 04:52 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
anmar A
May 2, 2015 06:59 PM
Drtryder
Apr 22, 2015 04:17 PM
QuickSilver02
Apr 7, 2015 11:12 AM
