How hard to change output shaft (T-56)
Old Feb 8, 2005 | 03:20 PM
hotrod18_69's Avatar
I am looking at a T-56 from a guy and it needs a new output shaft. The splines are bent due to his driveshaft builder making the DS too short.
What all does it take to take out and put in the output shaft.
Any help would be greatfull.
Thanks Brad
Old Feb 9, 2005 | 12:42 AM
SSBOY 2 N V's Avatar
Re: How hard to change output shaft (T-56)
No, its not that hard to replace the output shaft. First thing that I would do, it price a output shaft. You might be able to buy a good used trans for about the same amount of money. Second, you will not need any special tools for this job except a 5/16 punch, for the shifter. Then the output shaft should just slide out. Bob
Old Feb 27, 2005 | 10:01 AM
crzhrs's Avatar
This can NOT possible be right! I am about to change out my output shaft and I looked over the T56 manual and there are about a million other things you have to do to get that shaft out! Someone correct me if I am wrong.
Old Feb 27, 2005 | 09:05 PM
Ok, first off you take off the shifter, and punch out the roll pin, then pull off the tail shaft. Then take off the lid. There is a snap ring holding on the syncro, punch out the roll pin, and take off the syncro. After the syncro is off take out the rollar bearing and the bearing race. Take the quill off that holds on the imput shaft. pull the imput shaft out, then the main shaft should be able to slide out the top.
Victor Lamb
Aug 26, 2017 02:52 PM
blac94Z
15
Mar 2, 2015 12:00 PM
armedtrigger
Feb 24, 2015 08:30 PM
importkiller94
Jan 17, 2015 09:03 PM
centric
Aug 15, 2002 09:04 PM
