transmission mounts?
Old Feb 4, 2005 | 01:20 PM
blind527's Avatar
ok i have a 97 formula. everytime i accelerate i hear a huge banging against the outlet of my transmission *the part where it comes up from the floor* if there is a loose transmission mount, how do i fix this??? if it needs to be replaced how much and where can i buy them?
Old Feb 4, 2005 | 04:08 PM
Re: transmission mounts?
There is a single block of rubber, under the tailshaft of the tranny, resting on the tranny cross-member. You support the weight of the tranny on a floor jack, unbolt the mount and drop the cross-member, put the new one in and reverse the procedure. Very easy, other than the fact you are laying on your back under the car.
You could simply buy a stock mount, move up to the "1LE" mount which is a little stronger, and doesn't seem to increase vibration a whole lot, or use an Energy Suspesnsion poly mount that is virtually indestructible, but may cause increased noise and vibration that irritates some people. I doubt you would pay more than $25 for any of those, from the right source. Many auto parts stores carry the ES piece, or a stock replacement, since GM has been using the same mount for about 40 years. The "1LE" would be a dealer item... find the part number (Shoebox has it on his site) and get in touch with Jason Cromer.
Old Feb 4, 2005 | 04:31 PM
blind527's Avatar
thanks a lot man, does that seem like a transmission mount problem??? i heard its very common on 97's.
PublicEnemy1
Apr 7, 2015 12:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Timberwolf
Sep 2, 2002 10:42 AM
FlyboyZ28
Apr 10, 2002 04:12 PM
