Adding Oil to A/C System
Old Jan 27, 2005 | 06:50 PM
CamaroZBoy's Avatar
Does anyone know the exact amount of ounces that are supposed to go in a new replacement A/C compressor as well as how much oil ( in ounces ) should be in the entire system period...? Thanks
Cory
Old Jan 29, 2005 | 12:06 AM
Lt1t56's Avatar
Re: Adding Oil to A/C System
I read this somewhere and not sure how accurate this is. The system holds 8oz of oil and if replacing A/C parts add 2oz per part. Example.. if replace compressor 2oz, dryer 2oz, evaporator 2oz, condensor 2oz. When I replaced my compressor and dryer 2 years ago on my Z I added 4oz. to replenish the oil on the 2 parts that I replaced and to this date everything has been fine. Maybe someone can chime in with some more accurate info to confirm this.
Old Jan 29, 2005 | 12:46 AM
99andMine's Avatar
The easiest way to measure excactly how mush you need is to pour the amount out of your old compressor into a graduated cylinder and refill using that exact amount. But, some compressors come with oil already in them. Also, make sure to add R14-a compatible oil.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
jasonduaine
Mar 7, 2015 09:44 AM
alphaauto
Feb 5, 2015 05:25 PM
