Radiater cap keeps getting stuck on.
Old Jan 23, 2005 | 01:58 AM
MakoLS1's Avatar
Red face Radiater cap keeps getting stuck on.
My radiater cap keeps getting stuck on. The only way to get it off is to bend the metal teeth on the cap. The metal teeth from the cap look like they are twisting away from the plastic hinges on the radiater but it still dosent come off unless i bend the metel teeth from the cap and pry it off. Has this happen to anyone else? Nothing appears to be wrong with the radiater!!!
Old Jan 23, 2005 | 02:07 AM
jasycZ28's Avatar
Re: Radiater cap keeps getting stuck on.
are you pressing it down as you turn it?
Old Jan 23, 2005 | 02:12 AM
MakoLS1's Avatar
Unhappy Re: Radiater cap keeps getting stuck on.
Yes, i just went out and tried again. It does only turns like half an inch or mabey an inch if that.
Old Jan 23, 2005 | 02:16 AM
jasycZ28's Avatar
Not trying to be mean but mine takes some force. If it moved an inch than i would guess thats your problem.
Old Jan 23, 2005 | 02:18 AM
MakoLS1's Avatar
I dont want to mess up the plastic radiater by useing to much force!!! Its not like you can get a good grip around the cap either where its positioned.
Old Jan 23, 2005 | 09:36 AM
moparman's Avatar
Push down with the palm of your hand, while using the palm to turn the cap. You don't use your fingers.
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Fatdog2
Apr 27, 2015 10:32 PM
Biggiebound
Apr 23, 2015 08:50 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
